BT Series
Retrofit Battery Inverter I 5-10 kW I Three Phase I HV
Fanless & quiet
Elegant & compact
Easy retrofit for optimised energy autonomy
Increasingly, owners of PV systems are looking to expand into energy storage solutions, thereby enabling energy back-up and enhanced independence. Ideal for solar power system upgrades and retrofit projects, the BT battery inverter is installed on the AC-side of the on-grid inverter and can be combined with a range of battery capacities, including GoodWe high-voltage battery series Lynx Home F.
UPS level switching < 10ms
Smart home integration
IP66 ingress protection
Compensates asymmetry Charging/Discharging
Fanless & quiet
Elegant & compact
Optimised Energy Autonomy
High backup output power with overload capability. Wide battery voltage range (180-600V) supports various battery capacities and power.
Integrated dynamic power export limit
Modern and Compact Design
Elegant and compact design, with a high output without taking up much space. All connections are available on the bottom side of the inverter, making the installation and maintenance easier.
Fanless cooling
Easy to handle
ΕΠΙΣΚΟΠΗΣΗ
GW6K-BT
180~600
Max. Charging / Discharging Current(A)
25/25
400/380, 3L/N/PE
6600
6000
GW8K-BT
180~600
25/25
400/380, 3L/N/PE
8800
8000
GW5K-BT
180~600
25/25
400/380, 3L/N/PE
5500
GW10K-BT
180~600
25/25
400/380, 3L/N/PE
11000
10000
