DNS Series
3-6 kW | Single phase | 2 MPPTs
Fanless
Noiseless
GoodWe DNS series is a perfect match for residential installations thanks to its compact size and light weight. Manufactured for durability and longevity under modern industrial standards, GoodWe DNS series is IP65 rated so it can be mounted either inside or outside your home. With a low start-up voltage of only 80 V and the widest MPPT voltage range of 80-550 V, these inverters can provide greater options for your household system. The GoodWe DNS series is also extremely light, 30% lighter than other inverters.
80V start-up voltage
Wide range of MPPT voltage
Fanless and noiseless
Small, light weight & easy to install
Export control
Flexible communication methods
Fanless
Noiseless
Export Control
Control the amount of power exported to the grid up to zero output, in compliance with your electricity utility's requirements.
Easy Installation & Maintenance
With its compact size, simplified wiring, and weight 30% lighter than similar products, this inverter is extremely easy to install and maintain to save you from troubles during usage.
Various communication options
30% Lighter than similar products
20% Volume optimization
ΕΠΙΣΚΟΠΗΣΗ
GW6000T-DS
Max. Input Voltage (V)
13
Weight (kg) :
13.5
220/230
GW5000T-DS
13
Weight (kg) :
13.0
220/230
GW4200T-DS
13
Weight (kg) :
13.0
220/230
GW3600T-DS
13
Weight (kg) :
13.0
220/230
GW3000T-DS
13
Weight (kg) :
13.0
220/230
GW6000D-NS
11
Weight (kg) :
13.5
220/230
GW5000D-NS
11
Weight (kg) :
13.0
220/230
GW4200D-NS
11
Weight (kg) :
13.0
220/230
GW3600D-NS
11
Weight (kg) :
13.0
220/230
GW3000D-NS
11
Weight (kg) :
13.0
220/230
