Low voltage
Latin
98.8%
Max. efficiency up to 98.8%
Full-load running at 50°C
String level monitoring
130% DC input oversizing
110% AC output overloading
PLC Communication
Low voltage
Latin
98.8%
DC input current 15A
GW12KLV-MT
Max. Input Voltage (V)
800
2/2/2
Max. Efficiency
12
220V,3L/PE
GW15KLV-MT
800
2/2/2
Max. Efficiency
15
220V,3L/PE
GW20KLV-MT
800
2/2/2
Max. Efficiency
20.7
220V,3L/PE
